- Sat Oct 02, 2010 6:44 am
#216399
I have tested the CKP, upper right coner on the crank gear.
I removed the connector of the CKP on a same engine, differnt year,
the car starts and run, the engine light will come on while the car is running.
with that test, you can rule out the CKP sensor will prevent spark. Since
the same engine will run with the CKP sensor being disconnected.
I did this test to rule out the CKP sensor, difficult removing the pulley bolt.
I would like to avoid that unless an absolute is required.
I will swap the harness and see how things go.
As I stand, NO SPARK IS PRESENT.
