- Sun Mar 22, 2009 4:24 pm
#104954
"Kit" just means it comes with the little plastic clutch alignment tool. You need that if you're doing this yourself. You also need the correct sockets. It's something like a 12mm 12 point socket; check the manual. And a torque wrench is critical.
I got an Exedy OEM replacement clutch and 11lb flywheel. I wouldn't recommend anything lighter than that. And if this is strictly a street car, I would just resurface the factory flywheel.
People go way overboard with their clutch and flywheel. You don't need some crazy clutch that can handle a ton of power and some super lightweight flywheel. You're going to hate driving the car afterward. OEM replacements are fine for the amount of power 90% of us will see.
