- Wed Nov 19, 2008 6:38 pm
#79482
I think this would be an excellent thing to discuss. Anyone have tips, or rule of thumbs?
LowTEC-Derbo wrote:dont drop the clutch. that will kill your drivetrain![]()
i usually pull the handbrake. release the clutch to near the catchpoint where the car starts to move a little forward, and then slip the clutch off so its a clean launch. I haven't broken axles since I learned this way. I done plenty of 7200rpm launches on slicks like this.
I used to drop the clutch with the rpms at 4-5krpm and it snapped my axle. Course I'm sure on a stock motor, the torque might not be enough to snap it, but better to have a good technique perfected before getting more power.
Method wrote:Tips to getting a "good" reaction time
DO NOT WAIT for the green light to come on.
The yellow ambers will flash 1 at a time .500 seconds apart
When the 3rd amber(yellow) light goes on LAUNCH your car. if you do that you will see a decent reaction time. once you get consistant you can tune yourself from there. perfect reaction at sparta is a .000 if you wait for the green your most likely comming out with a 1.xxx which is terrible
Coles notes Launch your car on the 3rd yellow light NOT the green
JUICE wrote:Race cars are like boats I guess. Time to bust out another thousand.
sdots wrote:Method wrote:Tips to getting a "good" reaction time
I do the same ^^ however no handbrake, just perfect your clutch bite point.
not so on point so the tranny engages power to the fly, however just before, works a treat for me everytime, haven't been on the strip yet, however on the road it works great. Good tires also help
TurboHatch wrote:sdots wrote:Method wrote:Tips to getting a "good" reaction time
at the track you will want to use the ebrake to hold you still, reason is if you have a little to much engagement you will move out of the beams and redlight
Sentry wrote:Unless you're making serious power and are on slicks, I just see second killing your sixty foot time, and thus, your run.
