- Tue Nov 17, 2009 8:52 pm
#156983
i would say ecu and run the v-tec wires. all your axels and stuff will all be the same. same engine just vtec. and im sertin somone on here will tell you exactly what to do. im not familuer with the vtec wiring.
egsedanguy wrote:i would say ecu and run the v-tec wires. all your axels and stuff will all be the same. same engine just vtec. and im sertin somone on here will tell you exactly what to do. im not familuer with the vtec wiring.OK.. I have located this HONDA CIVIC EG/EJ OBD1 D15B SOHC VTEC ENGINE which I am about to order.... I am not familiar with the codes ( EG/EJ OBD1 ) but would this be a good swap for the d15B ?. Also, is the ECU that you say is the Electronic Control Unit and should I ask the seller to provide me with one ?
1992 Honda Civic LX
