ECU, Wiring, Sensors
By xNETZx
#168869 Hi guys can anyone tell me how is this trick done haha
i want my corners to be on all the time when the head lights are on :?
thanks in advance
By TrailerTrash
#168876 Cut and splice a few wires I would assume.
By edcortez9
#168880 what? im confused?!?! thats how it suppose to be
By TrailerTrash
#168884
edcortez9 wrote:what? im confused?!?! thats how it suppose to be
Something didnt seem right I had to come back here and read it again and now I too am confused :(
By 3kkl3sia
#168886 correct me if i am wrong, but because he isn't in the US.
im guessing that over there the corner lights dont have to turn on when the headlights do
just a guess though, only thing that makes sense
By xNETZx
#168895 ok maybe this i will try to explain
see the red civic and its corners and see the black eg
since my car is edm it is the same as the red one my amber are not working all the time only blinking when turned is on
and i want to know how can i make them glow all the time
By 3kkl3sia
#168899
xNETZx wrote:ok maybe this i will try to explain
so i got it right, over there your corners dont glow when the headlights work
i would have to say get wireing....
By asianrob
#168902 our US cars have a third wire in a wiring harness. youd have to search what wire that is. or get an engine bay harness from a US civic and and go from there.
By xNETZx
#168904 haha easier said than done
i have no idea what am i suppose to do exactly
that is why i posted the topic
if somenoe can tell like
"cut this wire .. cut that wire ..and thats it haha"
By edcortez9
#168911 Ok I think I can solve this one for you but since your car is edm you have to tell me the color wires for your corner lights and tail lights just to make sure what wire to use...
By hatchie
#168962 ok heres the rundown in us our cars have a green wire which is the accessory wire and that makes it to where we can turn just our corner lights on and then click it one more time to make it corner lights AND headlights
see your car when you turn on your lights once >>> your citylights come on only! and then you click it again to turn the headlights on.
all you would have to do is get a usdm corner pigtail and wire up the black and red together again and then run the green wire all the way up to your switch (as far as wiring it where i will leave to some1 more educated at this) but that will make it to where you will need double filliment bulbs in the corners as well cuz they will always stay on but also blink brighter for turns/hazards. and bam you got usdm corners pretty simple just gotta find some1 who could give you wiring diagram and pix
By edcortez9
#168979
hatchie wrote:ok heres the rundown in us our cars have a green wire which is the accessory wire and that makes it to where we can turn just our corner lights on and then click it one more time to make it corner lights AND headlights
well what i was thinking if he turns his switch all the wa on the headlights come on so i would take the positive signal from the headlight and jump it to the corner lense to make it come on everytime the headlights are on... but then your right about the bulbs so your idea is better cuz mine require a little custom modifying
By xNETZx
#169230 thanks for the replys guys
today i will take a look and see what can i figure out
By Civicz
#195495 I have a Eg4 in the UK and i'd like to do this to mine but i have no idea where to start at
