- Thu Jul 09, 2009 4:39 am
#129444
well since i have been here i have done city lights to pretty much all my cars except my integra and lex... so i made DiY
tools:
Phillps head screw driver
Drill
Drill bit like this it is 5/8th
another drill bit (regular kind i didnt think to take a pic of it for somereason)
wire splicers
electrcal tape (or but connectors)
air tool with air gun attache.
razor blade
silicone
OTHER things you will need
may need some extra wiring
pig tails for a Chevy side marker (part number shown along with part
Also you would need 168/194 bulbs for it..
i used 194 LED 's
first and foremost. i am not responsible if you mess your car up
ok now
heres what it looks like with one side done. (note city lights are on parking lights setting.)
first take off your headlights and also take out headlight bulbs
on the back of the housing you will see 2 circles one on each side of the headlight bulbs this is where i made my spot
NOTE DONT DRILL TO CLOSE TO THE HEADLIGHT BULB area because you CAN hit the bracket for the fucking headlight. and thats what happened when i did it. i didn’t get to close but close enough where my bulb its. anyways
this is what it would look like after wards.
Ok for the razor blade part.. you may or may not need to trim the socket. you will know if you need to or not when you test fit it in there
ok so anyways now you got your shit drilled and test fitted and what not. when you have your socket in place its a good idea to place silicone around the drilled area so it wont fall out on FT or HA. and to keep moisture out.
end result.
thanks!
tools:
Drill
wire splicers
razor blade
silicone
i used 194 LED 's
ok now
end result.
thanks!
92 civic cx sold!!
white 92 civic Si (traded)
primered 94 teg sold
92 civic DX sold!!
93 red EX coupe parted out!
92 civic LX sold!!
90 240sx sold!
93 faded black EX coupe
92 civic DX sold!!
92 civic LX sold!!
90 240sx sold!
what gauge wire did you use??
Chance is a homo # 69
