- Sat Apr 03, 2010 11:03 pm
#185417
ok i picked up a 91 ef. car ran for about a month then one day nothing just cranking. checked fuel filter for pressure and plugs for spark and its all there and checked timing.. what am i missing? someone said crank sensor can go bad and not tell the ecu to "fire" injectors. i used to get a cel after about 10 min of driving.if it helps thanks
now it could be your crank position sensor, next it may be your injectors,,,,dpfi=2 mpfi=4 check the resistance etc....
next id look into your compression being that its an 91 it may not be that great.....so you may not have enough to start....
1980 volvo 242
2001 crv
2001 crv
