- Sat Aug 21, 2010 2:59 pm
#209923
I have a D16Y8 in my Civic EX with 38,000 miles on it. I just bought the car a little over a month ago and noticed it was getting between 19 - 23 mpg. Horrible I know. Does anybody have any ideas on how to improve gas mileage. So far I have replaced; Spark Plugs, Dizzy cap and rotor, Fuel filter, stock air intake with Cold air intake, header, belts, tires are new, cleaned throttle body, adjusted the valves, and did a seafoam treatment. Now I'm up to 27mpg, but I know I can get way better.
Any tips will be appreciated.
j/k but still put it up in the air and check to see if the pads are not rubbing the rotors. if so it could be a sticking caliper. also remove the caliper and see if the wheel rotate freely if not it could be a bad wheel bearing.
it he is around 29-36 mpg with an average of 30 mpg
