pandapoo4u wrote:whats the best way to get the old headgasket off the block
and how do i get the oil out of my coolant
razor and sandpaper
and there is a plug on the back of the block
i just drained the coolent and flushed out the cooling system
By pandapoo4u
#232174
razor and sandpaper
thanks
By eg84dr
#232761 manual would be easier cause it will be plug and play
auto you will have to convert wich isint hard but just ads to the list of things to do
heres a link for auto to manual conversion
not very detailed but might help you out
http://hondaswap.com/~pills/autotomanual.html
By pandapoo4u
#233352 so this is the peice that was dmaged it was basically a guide for the cam shaft so that it had no left or right play
i pulled the one off of my b8 head and it fit like a glove
so here is the b7 head ready to go...
yes i used it...
torque baby
By pandapoo4u
#233641 got the intake mani put on today working slow and indoors its freezing outside...
all i need now is the p06 ecu and ill be set...
By pandapoo4u
#233781 ok so weather is holding back this build... so in my spare time i guess it's time to see if there are any small upgrades to increase gas mileage this is going to be a dd thats driven like crazy does any one have a site where thats all they focus on
By pandapoo4u
#233813 Image
picked up everything i needed today and got the po6 auto ecu will do the manual swap and get pictures for you
By pandapoo4u
#235062
eg84dr wrote:post a vid if you can and describe the situation more and we will help you :thumb:
Ok so lets see
When I start the car it just turns right off unless I hold down the gas
When holding down the gas if I let off it bogs and shakes then dies
After keeping the rpms up long enough to get the car warm it will rough idle and rev high back an fourth with 2 sec intervals
Once I take the car around the block and its at running temp it idles like a champ
I have checked the gauge cluster the temp was stuck at half till I took it out and it fell off no more temp gauge...
The ecu is p06 auto to manual swap
I also have a p05 manual that I have swapped out and had the same issue
I have replaced 2 sensors that are in the head under the dizzy checked the thermostat its fine...
By pandapoo4u
#235277 so... i feel realllllly dumb... but yet i figured it out i had the tps and map sensor plugs reversed
runs amazingly smooth now
pandapoo4u wrote:so... i feel realllllly dumb... but yet i figured it out i had the tps and map sensor plugs reversed
that happen to me before lol
you feel a power diff?
By pandapoo4u
#235336
ok so car starts and idles now... i got it figured out around 9pm and i get up at 4am to go to work so i didn't try and drive it besides that its not registered and has no plates so i may be able to go around the block but not much further
there is still water in my oil im praying it was just leftover that needed the car to be ran to filter out
im going to replace the oil and hope it gets rid of it
but i need to replace my temp gauge or just the whole cluster i dont want the car to overheat and not know till it does damage
