- Mon Mar 28, 2011 4:00 am
#246649
This was a thrilling accomplishment as this was my first head swap as an enthusiast. I just finished replacing my cylinder head for the first time. A good 90% success but I am getting alot of white smoke after cranking the motor which probably indicates water leak somewhere...
I replaced the same head gasket twice (trial and error)... On my old head, I purchased a $26.00 regular gasket from a auto store, installed it and torqued the bolts to 80lbs. Discovered the cylinder head was bad. Next, I ordered a refurb cylinder head, changed timing belt, water pump, idle pulley, adjusted the valve clearance and did the timing on the distributor successfully. This time, after googling it, I torqued the bolts of the cylinder head to 50 lbs using the SAME gasket (second time around)
I fired up the engine and it cranked beautifully right away however with a lot of white smoke.
My compression test was 170-175 on all cylinders and a leak down test held the 90-100psi mark.
My question is... by lowering the torque the second time around, would water have swept thru the head gasket since it was torqued to 80lbs previously ? Also, I did not put those 2 alignment sleeves that goes to align the head onto the block when installing the head. Would that have any effect to the cause of the white smoke ? Or is my timing off with the distributor and I will have to get a timing gun and time it more accurately ?
My thoughts are that I may have to take the head out again and put in a Multiple layer steel gasket and those alignment pins if that will help fix the white smoke problem.. or maybe something else is the problem.. Your comments are greatly appreciated. ....
see photo ... http://s1094.photobucket.com/albums/i44 ... 7773-1.jpg
1992 Honda Civic LX
Everything points to leaking head gasket...
