- Tue Mar 18, 2008 10:41 pm
#46652
The Password:JDM True2Form 2.5 Test Pipes are a must for JDM fellas who want the extra HP normally lost with the use of a cat. These Test Pipes are engineered and built by PWJDM for PWJDM.
Made of T-304 Stainless, the True2Form Test Pipes are designed with Form, Function and Perfect fitment for all intended applications. All True2Form Test Pipes are 2 pieces in construction and are both telescopic and clock-able to accommodate a larger selection of Hondas. Being a True 2.5”, these are the largest diameter test pipes available on the market. You have a choice of either resonated or a straight flow design. Adding power has never been easier, than just unbolting a cat and replacing it with one of these. The Resonator chambered design will drop Db levels quite a bit compared to the straight flow version.
Robotically TIG welded, our Password:JDM True2Form Test Pipes are made using nothing but the best as always. Mill cast T-304 Stainless Flange, T-304 2.5 inch Pipes, are mated together using a precision robotic TIG welder for unmatched quality. Point blank, you won’t find a better test pipe for any price anywhere! Another great product from Password:JDM, what else would you expect from us?
Fitment:
All Honda cars with D, B, H, F series engines and Hybrid K series cars. Adjustment length: 15.5" to 19.5"
well I need a test pipe to fix my exhaust since my header doesnt bolt up to my original cat. so I am looking at getting one of these so i dont have to pay out my a$$ for a cat to get welded in place. but does anyone on here have one of these? or known someone that has used one? they seem like a quality product, but i want to make sure before i spend my hard earned cash on one.
Fitment:
