- Tue Mar 04, 2008 6:59 pm
#44730
Nice build, just wanted to point a few things out.
PCT pistons in a 1.8 block you are looking at 12.1+ compression. Also you might even need to cut the piston reliefs if you run Toda B's. I highly recommend you stick with B16A pistons if you want to daily this car even on 93. If you decide to stick with these pistons I recommend you clay the head more than once and valve lash the head correctly. Ur valve clearance is going to be tighter than a 12yr virgin haha. Only reason I am stressing this is because I had a similar set-up but I just JUN III's in my build but only clayed the head once and slapped it on. well lets say when I threw it on a dyno it didnt leave running hahaha.
Also if you havent read all over honda-tech yet ACL bearings only come in one size. So the chance of ur journals being in spec are slim. So you have to machine them to fit. I recommend just saving urself the worry and just pay out for some good OEM honda bearings.
But so far ur build looks good. GL DOGGIE
INLINEFOUR.COM
If you are in the Southern Ca. area, drop on by and visit our showroom.
11400 Knott Street, Garden Grove, CA 92841.
info@inlinefour.com Or
Sales@inlinefour.com
