- Wed Jul 23, 2008 7:05 pm
#63104
My a/c compressor when i get on the gas stops and then resumes but squeals in between every gear shift? How do i get it to stop squealing?
- Wed Jul 23, 2008 8:43 pm
#63121
My best guess is a new belt : D
- Thu Jul 24, 2008 5:54 pm
#63237
when i changed my belt it did that squeking noise....all becuase i didnt tighten it enough...after tighten it jus a little it stopped....maybe loosen the tensioner jus a little to see if it works...installing the belts too tight or too loose will make that sound...as ofr the tension, check out the haynes manual or the honda manual, they show the length of how tight/loose u should have in your belt
- Mon Jul 28, 2008 11:33 pm
#63687
If im not mistaken the deflection on the belt should be about an inch. Take a ruler and go to the beltand measure the distance from the belt being level to the furthest distance you can push it. That is your deflection. Im pretty sure that it should be about 1 in.
My sig was too large, I need to read the Rules & Guidelines
