- Wed Aug 13, 2008 2:59 am
#65669
I had taken out an older aftermarket cd player and installed another one i had found in my barn and after doing all the wiring and what not the unit turns on but shuts itself off automatically? I was wondering if maybe its an internal problem?
- Wed Aug 13, 2008 3:57 am
#65677
How did you wire it? Did you cut off the factory harness or did you use an adapter harness? How beat up is this radio?
- Thu Aug 14, 2008 3:45 pm
#65936
What do you mean you "used" the factory harness? You cut it off?
If the radio had the same problem before then you shouldn't be surprised if it continues to have the problem now.
- Sun Sep 07, 2008 3:27 pm
#68692
check your fused. check around for any exposed wire on the radio harness. if problem continue then i suggest u run ur own wire. 1 (constant power = yellow) straight to the battery or anything that give constant power. be sure to add a fuse on that wire just to be safe. the red wire to any fuse on the driver side fuse box. ground to ground. and you shouldnt have this problem again.
BOSS
#68693
check your fused. check around for any exposed wire on the radio harness. if problem continue then i suggest u run ur own wire. 1 (constant power = yellow) straight to the battery or anything that give constant power. be sure to add a fuse on that wire just to be safe. the red wire to any fuse on the driver side fuse box. ground to ground. and you shouldnt have this problem again. unless your speaker wires are makin contact somewhere.. check all speaker wires
BOSS
- Sun Jan 30, 2011 4:30 pm
#236168
X2 Check all your wiring and speaker wires. Any bare wires touching somewhere can cause problems. Took me a long time to figure this out in my old civic hatch. From experience I don't recommend cutting and splicing the stock harness or using electrical tape anywhere. Many cars I've bought have had crappy installation jobs with tape and they always short out eventually. Get a harness adapter and wire connectors.
